wart overvoltage protection...
On Sun, 2 Oct 2022 15:47:33 -0700 (PDT), Lasse Langwadt Christensen
<langwadt@fonz.dk> wrote:
mandag den 3. oktober 2022 kl. 00.40.26 UTC+2 skrev Clifford Heath:
On 2/10/22 23:35, Mike Monett VE3BTI wrote:
Lasse Langwadt Christensen <lang...@fonz.dk> wrote:
look closer at the schematic, the reverse protection does work
the first FET is reverse so initially the body diode will work as a
series diode and when the FET turns on so there is no voltage drop
Very nice catch. It works. Thanks.
I got tripped up on this recently. What\'d weird is that without the body
diode, the source and drain must be connected in the expected direction
(and it sorta works) but with the body diode, it *must* be in the
reverse direction. Very confusing at first sight.
fets without a body diode are very rare
The EPC gan parts don\'t exactly have a body diode, but turn on soft at
around -2 volts. Somehow.
On Friday, September 30, 2022 at 1:14:16 PM UTC-7, John Larkin wrote:
We make a gadget that\'s powered by a 12 volt wart, and sometimes a
user applies 24 and blows one up.
We have a polyfuse and a 12 volt TVS and they sometimes fry the TVS.
It\'s posssible that most any useful polyfuse+TVS combo can be teased
to destruction.
I think Phil H mentioned some gadget, a polyzorb or something, that
would be better. I can\'t find it.
Would that be a \'sidactor\'? This variant works for AC limiting,
should be OK with a polyfuse in series about not hurting a 24 supply
<https://www.littelfuse.com/~/media/electronics/datasheets/sidactors/littelfuse_sidactor_do_214_datasheet.pdf.pdf>
It has to be depowered completely to reset it, so the polyfuse will stay warm until unplugged.
The breakover is built-in, rather coarse, so one hopes your nominal 12V box is OK with 15...
John Larkin wrote more smartarse BS
Phil Allison
Sylvia Else wrote:
I like crowbars. No finesse required.
It can be done wrong.
** Yawwwwwnnnnn...........
** A 16amp triac with a 12v zener provides full protection.
Soft gate drive can be a hazard.
** Drivel.
Zener+triac could allow a couple of volts of negative swing.
Will trip at 13V with normal polarity and about 1.5V reverse.
Anyone stupid enough to use the wrong voltage/ polarity wall wart deserves to see it die.
Except that said stupid person will ship it back for us to fix.
** Ship a dead $10 wall wart to you ?
Get fucked.
........ Phil
mandag den 3. oktober 2022 kl. 01.23.29 UTC+2 skrev John Larkin:
https://www.ti.com/lit/an/snoaa36/snoaa36.pdf
Of course, but you can do it in some of the simulators.
On Mon, 3 Oct 2022 02:19:00 -0700 (PDT), Phil Allison
Phil Allison
** Drivel.
A soft gate drive, like just a zener, can make an SCR chip fire
locally, near the gate wirebond, and fry that region before conduction
spreads laterally. It\'s like 2nd breakdown failure in transistors.
There are specific crowbar controller chips to make a hard, fast gate
drive.
Look it up.
On Sun, 2 Oct 2022 17:52:38 -0400, Phil Hobbs
<pcdhSpamMeSenseless@electrooptical.net> wrote:
John Larkin wrote:
On Sun, 2 Oct 2022 13:13:39 +0100, Clive Arthur
to destruction.
We might fine-tune the polyfuse+TVS, or maybe go polyfuse and SCR
crowbar, or something.
This is all entangled with parts availabity. Ideally the box would
just work from 12 or 24, but that has separate complications.
We once used a TI electronic fuse IC, but it liked to blow up.
12V LDO regulator with thermal shutdown.
That would work if the LDO can stand +24v input. It still needs
reverse protection.
May as well just let it work from +10 to +40. The customer can use the
wrong wart and never notice the difference.
I suspect that negative-center warts are rare these days.
My next problem is a bulletproof UVLO and switcher sequencing.
Reverse protection is also important to protect against an input short,
which can blow up stuff by forcing currents from output to input.
That\'s one of the three ways to blow up a 317, and one of the two to
blow up an 78xx regulator. (Input overvoltage is the other main one,
and for a 317, discharging a big ADJ pin bypass backwards.
Cheers
Phil Hobbs
I once mightily abused an LM317 adjust pin to see if I could break it.
No feasible abuse did.
John Larkin wrote WORSE smartarse BS
** Drivel.
** Drivel.
FOAD you wanker.
.......... Phil
On Mon, 3 Oct 2022 16:13:42 -0700 (PDT), Phil Allison
** Drivel.
** Drivel.
FOAD you wanker.
......... Phil
https://tinyurl.com/mve5dtua
Center-gate SCRs are better than edge gates, but both benefit from a
hard fast gate drive.
to destruction.
reverse protection.
Cheers
Phil Hobbs
100 uF ADJ bypass, 30V output, short input to ground. That\'ll do it.
Cheers
Phil Hobbs
Dr Philip C D Hobbs
Principal Consultant
ElectroOptical Innovations LLC / Hobbs ElectroOptics
Optics, Electro-optics, Photonics, Analog Electronics
Briarcliff Manor NY 10510
http://electrooptical.net
http://hobbs-eo.com
