Troll-feeding Senile Asshole Alert!...
On Mon, 14 Feb 2022 09:45:20 +0100, Peeler <trolltrap@valid.invalid>
wrote:
On Sun, 13 Feb 2022 15:57:26 -0800, jlarkin@highlandsniptechnology.com,
another mentally deficient, troll-feeding, senile asshole, blathered again:
It can\'t. Maybe that yellow disk is not a capacitor.
Maybe that PROVEN clinically insane attention whore is just a trolling piece
of shit, senile twit? <VBG
I suspect he knows more about electronics than you do.
I yam what I yam - Popeye
On Mon, 14 Feb 2022 09:43:43 +0100, Peeler <trolltrap@valid.invalid>
wrote:
On Sun, 13 Feb 2022 20:11:04 -0800, jlarkin@highlandsniptechnology.com,
another mentally deficient, troll-feeding senile twit, babbled again:
You could
Think hard about it
LOL Troll-feeding senile asshole still hasn\'t checked what\'s going on!
Do you know anything about electronics?
On Mon, 14 Feb 2022 09:41:57 +0100, Peeler <trolltrap@valid.invalid>
wrote:
On Sun, 13 Feb 2022 15:59:33 -0800, jlarkin@highlandsniptechnology.com,
another mentally deficient, troll-feeding, senile asshole, blathered:
Try an ohmmeter.
Try not to play that clinically insane troll\'s game, senile twit! <tsk
Do you own an ohmmeter?
On Mon, 14 Feb 2022 07:47:20 -0800, jlarkin@highlandsniptechnology.com,
You poor troll-feeding senile idiot STILL didn\'t get it! <BG>
On Mon, 14 Feb 2022 17:37:59 +0100, Peeler <trolltrap@valid.invalid>
Confirmed.
On Mon, 14 Feb 2022 08:36:44 -0800, jlarkin@highlandsniptechnology.com,
Do you know anything about the troll who you keep supporting, you demented
senile twit? <BG>
On Mon, 14 Feb 2022 08:37:29 -0800, jlarkin@highlandsniptechnology.com,
Do you have any pills against senility, troll-feeding senile asshole? TAKE
them!
On Mon, 14 Feb 2022 09:15:31 -0800, jlarkin@highlandsniptechnology.com,
Confirmed.
Your senility, yes!
On 2022-02-14 03:58, Commander Kinsey wrote:
On Mon, 14 Feb 2022 00:54:02 -0000, williamwright
wrightsaerials@f2s.com> wrote:
On 14/02/2022 00:47, Commander Kinsey wrote:
Unless NiCads are vastly different to car batteries, one shorted cell
makes a hell of a lot more current flow.
They are vastly different.
Do they not both have a very low internal resistance?  Therefore
connecting a 10V battery to a 12V charger makes too much current flow?
Yes. With a charger as you described, yes.
Cheers, Carlos.
On Mon, 14 Feb 2022 21:04:42 +0100, Carlos E.R., yet another brain dead,
troll-feeding senile ASSHOLE, blathered:
Another demented senile asshole who doesn\'t get what\'s going on! LOL
On Mon, 14 Feb 2022 20:30:52 +0100, Peeler <trolltrap@valid.invalid>
them!
I\'ll take that answer as \"no\". Or maybe \"what\'s an ohmmeter?\"
If a man will begin with certainties, he shall end with doubts,
but if he will be content to begin with doubts he shall end in certainties.
Francis Bacon
On Mon, 14 Feb 2022 13:40:46 -0800, John Larkin, another demented senile
asshole, blathered:
them!
I\'m happy to see that you felt PERSONALLY addressed when I mentioned \"pills
against senility\", senile asshole! <BG>
In article <op.1hjp1807mvhs6z@ryzen.lan>,
Commander Kinsey <CK1@nospam.com> wrote:
https://imgur.com/a/b8l5qKQ
Look at the circuit diagram. The positive of the battery is only connected through a capacitor.
How can a capacitor possibly pass DC current to allow the battery to charge?
I don\'t believe that it could.
My guess is that schematic misinterprets the nature of the yellow
disc. I suspect that it\'s not a capacitor at all, but is a
positive-temperature-coefficient thermistor - a \"soft fuse\". If the
output (to the battery) is accidentally short-circuited, the high
current flow through the PTC will cause it to heat up, increasing its
resistance, causing it to heat up even faster, causing its resistance
to increase even more... and thus limiting the current flow through
the short circuit. These PTCs usually have a \"hold current\" (which
they will allow to pass for an unlimited amount of time, at room
temperature) and a \"trip current\" which will heat them enough to cause
them to limit the current.
Since we don\'t have a profile view of this component and can\'t see
the markings, I can\'t tell for sure.
On Mon, 14 Feb 2022 15:13:04 -0800, Dave Platt, yet another mentally
deficient, troll-feeding senile asshole, blathered:
I believe the trolling Scottish wanker and attention whore can make ANY of
you senile assholes suck him off as often as he wants to be sucked off by
one of you, senile cretin!
disc.
** You been sleeping ?
That was obvious two days ago.
** The trade name is \" Polyfuse \".
They show very low cold resistances and will snap to a high value when hot.
Used for loudspeaker, battery pak and transformer protection.
Slow acting but self resetting, many times.
...... Phil
On Tue, 15 Feb 2022 10:20:58 +1100, Peeler <trolltrap@valid.invalid> wrote:
Whoops, the gutless stalker has been kicked out of yet another usenet
server, again.
On Mon, 14 Feb 2022 20:31:27 +0100, Peeler <trolltrap@valid.invalid>
Confirmed.
Your senility, yes!
Generating lame, profane insults is a common skill set. How\'s the pay?
Francis Bacon
I assume you mean a capacitive dropper? I have an LED room light like that. That would be the capacitor limiting current in the AC part, but in this case it was in the DC part. I\'ve been told it isn\'t a capacitor, but an automatic resetting fuse, which looks exactly like a ceramic disk capacitor.
On Mon, 14 Feb 2022 09:30:20 -0000, Brian Gaff (Sofa) <briang1@blueyonder.co.uk> wrote:
Its called a lossless charger. I encountered something like it in an old
pifco charging circuit in a torch. From what I could see one rectifier one
large capacitor and a small bleed resistor across the mains pins was all
supposed to charge two flat Ni-cads, and it was fine until the capacitor got
leaky, and the room filled with nasty smelling smoke.
I\'m just guessing here, since I cannot see your circuit, but it used to be a
very common practice for small rechargeable devices.
Brian
On Mon, 14 Feb 2022 12:22:30 -0000, Paul <nospam@needed.invalid> wrote:
On 2/13/2022 5:33 PM, Commander Kinsey wrote:
On Sun, 13 Feb 2022 20:55:51 -0000, Rick C <gnuarm.deletethisbit@gmail.com> wrote:
Look at the circuit diagram. The positive of the battery is only connected through a capacitor. How can a capacitor possibly pass DC current to allow the battery to charge?
Maybe it\'s an AC battery? They are very useful for grid storage applications as long as you can control the phase.
What makes you think that component is a capacitor? I\'m assuming you drew the schematic.
I\'ve learned from someone on Quora that it\'s actually a PTC Fuse - a resettable semiconductor fuse.
The second image in the link shows a brown disk, which I thought was a ceramic capacitor. Looks like it\'s to stop a busted battery from being overcharged when a cell has died.
The shape of the edge of the device,
hints that it is not a disc capacitor.
One reason for that, is the material the yellow
thing is dipped in, is a hell of a lot harder,
than the softer stuff used on the older disc caps.
The yellow material might be intended to be
flame proof or the like.
As a connoisseur of circuits, I bet you\'ve already
made up your mind as to whether this circuit is a
good idea or a bad idea...
It\'s not going to be used anymore anyway. It was for NiCads (which are too old and tired), and I\'m changing the battery packs to LiIon, which I\'ll just charge form a bench supply.
