How long to charge 9v nimh battery...
A
AK
I have a 9V 180 ma discharged Nimh battery that I am charging at 25ma.
How long will it take to charge?
Thanks,
Andy
** What you have is a 180 mAh battery: h = hour.
You do the math.
....... Phil
Am Sonntag, 19. Dezember 2021, um 05:57:15 Uhr schrieb AK:
25ma.
Isn\'t it 180mAh?
milliampere hours and not only milliampere?
(180mAh)/(25mA)=7,2h
On Mon, 20 Dec 2021 11:22:04 +0100, Marco Moock <mo01@posteo.de>
25ma.
Isn\'t it 180mAh?
For nickel based batteries, you normally add 40-50% to compansate for
charging efficiency.
RoRo
** The OP posted a question from some test he had to do.
So no such correction factor is needed.
For slow charge (8hr) rates - 40% might be OK.
But absolutely not for fast charging, or the cells will cook.
...... Phil
