When Kula needed water to stop wildfire, it got a trickle...
F
Fred Bloggs
Many other US cities are also vulnerable
This is another major headache in the making, it will be a requirement for climate resiliency.
https://apnews.com/article/fire-maui-kula-hawaii-water-pumps-epa-285a21f64d20d2a58a5c420f5a04a218
Of course they\'re jumping on diesel backup generators, but it could be biodiesel or a synfuel, not necessarily petro-diesel. Whatever they select, it should have a long storage life.
One way to conserve water in an emergency is to shut the users off. Apparently almost all the smart water meters have remote shutoff capability, it\'s quite a money saving feature ultimately. The question is where do the meters get the power to do this: 1) mains derived power, 2) battery power, 3) water pressure power. Obviously only 2) is going to work in an emergency catastrophe scenario.
The idea of using satellite communications to transmit meter status in real time is brilliant. That will work except in times of a supervolcano eruption.
example of water pressure operated shutoff:
https://www.waterworld.com/water-utility-management/asset-management/article/14038447/remote-disconnect-metering
\"One way to conserve water in an emergency is to shut the users off.
very stupid idea
what matters is water retention (Nobel Prize)
and reduced use of tap water,
so smart water meter should work 2 modes:
1. full shutoff
2. reduced water flow
So the marketed product represents an old 1-0 logic technology
and should be replaced by fuzzy logic gear
1.0, 0.8, 0.5, 0.3, 0.1, 0.0
x water flow
Darius the Dumb has posted yet one more #veryStupidByLowIQaa article.
very stupid idea
1. full shutoff
I\'m not sure there is such a thing as reduced water flow. The idea is to keep the pipes pressurized. Reduced flow means reduced pressure.
The shutoff scheme would work the same as rolling blackouts.
They can\'t do much by way a fairly high duty cycle on/off\'s at the meter, as they might run down the batteries. They can certainly permanently shut down a meter reporting excessive non-stop use, indicating possible damage.
x water flow
The absolute arsehole \"Darius the Dumb\" persisting in being an Off-topic troll...
a a <manta103g@gmail.com> wrote:
X-Received: by 2002:a05:620a:1a2a:b0:774:cd1:f036 with SMTP id bk42-20020a05620a1a2a00b007740cd1f036mr138453qkb.14.1696618324345;
Fri, 06 Oct 2023 11:52:04 -0700 (PDT)
X-Received: by 2002:a05:6830:1096:b0:6be:f835:6e5f with SMTP id
y22-20020a056830109600b006bef8356e5fmr2617536oto.6.1696618324131; Fri, 06 Oct
Path: not-for-mail
Newsgroups: sci.electronics.design
Date: Fri, 6 Oct 2023 11:52:03 -0700 (PDT)
In-Reply-To: <8601dd97-b231-40f2-bd9d-42c136f87285n@googlegroups.com
Injection-Info: google-groups.googlegroups.com; posting-host=46.134.172.232; posting-account=XS5sXwoAAABKU0kHcsk_nashWaidAu0Q
NNTP-Posting-Host: 46.134.172.232
References: <8601dd97-b231-40f2-bd9d-42c136f87285n@googlegroups.com
User-Agent: G2/1.0
MIME-Version: 1.0
Message-ID: <0ad8307f-1817-4af7-bb1a-33242f280b5bn@googlegroups.com
Subject: Re: When Kula needed water to stop wildfire, it got a trickle
Injection-Date: Fri, 06 Oct 2023 18:52:04 +0000
Content-Type: text/plain; charset=\"UTF-8\"
Content-Transfer-Encoding: quoted-printable
X-Received-Bytes: 2894
The idiot Fred Bloggs <bloggs.fredbloggs.fred@gmail.com> persisting in being an Off-topic troll...
Fred Bloggs <bloggs.fredbloggs.fred@gmail.com> wrote:
X-Received: by 2002:a05:620a:126e:b0:775:7724:622a with SMTP id b14-20020a05620a126e00b007757724622amr118846qkl.14.1696623171174;
Fri, 06 Oct 2023 13:12:51 -0700 (PDT)
X-Received: by 2002:a9d:7f88:0:b0:6b9:a955:43bc with SMTP id
t8-20020a9d7f88000000b006b9a95543bcmr2748806otp.3.1696623170651; Fri, 06 Oct
2023 13:12:50 -0700 (PDT)
Path: not-for-mail
Date: Fri, 6 Oct 2023 13:12:50 -0700 (PDT)
In-Reply-To: <0ad8307f-1817-4af7-bb1a-33242f280b5bn@googlegroups.com
Injection-Info: google-groups.googlegroups.com; posting-host=2601:5cc:4701:5250:6538:4655:e952:d786;
posting-account=iGtwSwoAAABNNwPORfvAs6OM4AR9GRHt
NNTP-Posting-Host: 2601:5cc:4701:5250:6538:4655:e952:d786
References: <8601dd97-b231-40f2-bd9d-42c136f87285n@googlegroups.com> <0ad8307f-1817-4af7-bb1a-33242f280b5bn@googlegroups.com
User-Agent: G2/1.0
MIME-Version: 1.0
Message-ID: <58152222-e6be-43bc-bc50-a53af32a61e0n@googlegroups.com
From: Fred Bloggs <bloggs.fredbloggs.fred@gmail.com
Injection-Date: Fri, 06 Oct 2023 20:12:51 +0000
X-Received-Bytes: 3624
