Testing small Transformer questions...
S
StevWolf
I have a dead Ac/Dc adaptor. I\'m busted it just to learns stuff.
Im trying to learn how to test Transformers. This transformer says on it AMS10405 RG 1320F. I provide this to give all information, however Im not sure it matters much to my question.
I have so far removed from what I can gather are the Primary wires from the board. I assume they are because they are white and black and are literal wires going into transformer, as oppose to all the other connections which appear to be pins in the circuit board. I believe to properly test transformer you need to remove it fully eventually.
Here are my results with digital tester, When set to continuity, which appears to be (2) ohms setting. I get Beep and .002 Ohms.
This seems to be very low ohms.
I do find it difficult when any information on testing transformers says check with the data sheet. I\'m sure someone will say sure here is the information its easy to find.
Does .002 Ohms seem right for the primary.
Regards
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA512
Can\'t find the part with a quick google. I\'m going to assume it\'s not
generally for sale (e.g. only sold in the Chinese market for making
other stuff with; or old).
Might be that you\'re misinterpreting the meter. Mine here _always_
shows the decimal point when in continuity mode. If yours is like mine
in that regard, it\'s not supposed to be read as \"2 milliohms\", but
rather \"2 ohms\" (which might be a concerningly high value, depending on
how large this transformer happens to be).
Quick sanity check for yourself -- grab something you know the
resistance of (or can check easily), such as a 100 ohm resistor. You\'ll
probably see it displayed in the range of \" .105\" to \" .095\" (under the
assumption of a standard 5% tolerance resistor).
My meter here does have some error between resistance and continuity,
generally with continuity mode showing an ohm or two less than
resistance mode; at least across the 10 resistors I tested with just
now.
HTH :)
-----BEGIN PGP SIGNATURE-----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=o56G
-----END PGP SIGNATURE-----
|_|O|_|
|_|_|O| Github: https://github.com/dpurgert
|O|O|O| PGP: DDAB 23FB 19FA 7D85 1CC1 E067 6D65 70E5 4CE7 2860
now.
HTH :)
Well thanks for your comments. You have encouraged me to dig into my meter a bit.
Here are some results of my meter using some resistors I have.
100R set to 200 is 107 Ohms - Ok I guess
1 R set to Continuity says .974 Ohms - Yes seems OK.
..39 R set to Continuity says .002 - thats close
..39 set to 200 says 3.6 (which seems odd to me)
Importantly The manual for the for the meter seems to say that it will show continuity for anything less than 50ohms.
Also while the meter has no information about the following, in the manual, when I set it to Continuity there is a little 2 under the decimal point, in the same way that it shows up when set to 200 for example with the respective 200 under the decimal. I asume that means 2 Ohms,
Sooo Im still trying to figure out if this transformer primary is bad?
Maybe transformers which are basically two sets of winding in simple transformers dont have much resistance.
I mean wire has loss but not a lot. ??
Again Im just trying to learn and understand.
Hash: SHA512
[on 2023-02-22, I wrote]
now.
HTH :)
meter a bit.
107 ohms is within 10% tolerance; so it\'s fine assuming it\'s got a
silver (or no) tolerance band. What did this show in continuity mode?
The range doesn\'t \"really\" come into play here (it just means you can
accurately measure from 0 Ohms to 199 Ohms; usually to the nearest
tenth)
What did this resistor show in Resistance mode? I mean if your display
works the same as mine, it\'s showing just shy of 1k ohms.
With the assumption your display operates the same as mine, 2 ohms is
nowhere near 0.39 Ohms. Likewise if it really is showing milliohms; 2
milliohms is nowhere near 390 milliohms.
3.6 ohms reading on a 3.9 ohm resistor is within 10% tolerance. Color
marking would be Orange, White, Gold; with a Silver (or no) tolerance
band.
(0.39 ohms would be Orange|White|Silver).
Means it\'ll beep if the circuit total resistance is 50 Ohm or less -- so
a 100 Ohm resistor will never beep, but a 47 Ohm resistor most likely
will (noting, of course that 10% tolerance can get you as high as 51
Ohms).
2 Ohms,
What\'s the meter make/model?
You get continuity, chances are \"no\", unless it\'s supposed to have more
resistance than it does. But we\'d need a datasheet or technical manual
to know for sure (I mean I have a couple of old rail locomotive
maintenance manuals that\'re like \"if you need to rewrap the solenoid,
use 28AWG magnet wire until you get 75 ohms in the coil\")
Depends on the wire gauge. For example, 30 AWG magnet wire is something
like 100 Ohms / 1000 feet.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=812U
|_|O|_|
Hash: SHA512
now.
HTH :)
meter a bit.
tenth)
band.
Ohms).
2 Ohms,
=812U
|_|O|_|
Well to try to answer questions,
100 ohm Resistor on continuity is .145 oddly
..39 ohm Resistor on 200 scale is 7.6 again oddly
Model of meter is MTP model 2322
The thing is its dashes ones Hope\'s when every website on testing says check data sheet, when they are so scarce if at all. And the numbers on the transformer so cryptic. I get that you need it but, they seem hard to come by so i assume you there must be charts to guestemate .
I dunno.
Regards.
Hash: SHA512
tenth)
Okay, and it shows 100 (+/- 10%) on the Resistance scale?
What\'s the banding on this resistor? Also; have you checked the leads
themselves?
I can\'t find a single thing about this online. Must be old?
No, there are datasheets... but old stuff might not have them (or
they\'re limited to china markets )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=9ZVm
|_|O|_|
Hash: SHA512
tenth)
themselves?
Yes the 100 ohm resistor shows 100 ohms on the 200 scale.
The .39 ohm resistor is a 2 watt orange, white, silver, gold.
The leads are in good condition.
Actually I have found several links for this meter. Here is one.
https://www.directindustry.com/prod/mtp-instruments-inc/product-131921-1932654.html
Well as far as data sheets for transformers I find for me anyway, I do not find them as easy to find as common as other small parts, I mean you can find a data sheet on almost any old transistor, triac diac or component etc. But l find transformers less available. And if Chinese transformers are less likely then we are really out of luck as almost everything is made there..
Regards.
Hash: SHA512
themselves?
Perfect. Sounds like the continuity scale is off by a considerable
amount then.
Perfect. That might simply be too low if the LOWEST range your meter
does is 200 ohms. You\'d likely want a 20 or 2 ohm range.
More that they can impart resistance / capacitance / etc into a circuit;
also selection of the terminals on the meter can matter.
Yeah, I found that too; but no real information to be had. They only
have a defunct link to the manufacturer\'s website for more details.
There\'s a difference between \"made for chinese markets\" (such as what
one finds inside a cheapo USB hub / power supply / etc), and \"made for
export markets\" (such as what one finds everywhere).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=hLbB
|_|O|_|
Hash: SHA512
tenth)
themselves?
Well as far as data sheets for transformers I find for me anyway, I do not find them as easy to find as common as other small parts, I mean you can find a data sheet on almost any old transistor, triac diac or component etc.. But l find transformers less available. And if Chinese transformers are less likely then we are really out of luck as almost everything is made there.
Regards.
Put that 100Ω resistor in series with the transformer primary and measure the resistance of both of them together.
It should read 190Ω to 500Ω.
I just pulled 4 random old style wallwarts and measured 90Ωs to 359Ωs.
Is this an old style transformer and diode style or a lightweight switching type wallwart?
Old style will only have a few parts maybe 6 or less. Is there a fuse that you can see?
Old style you won\'t see it, new style it may or may not be covered with heat shrink tubing.
Mikek
