H
hbaocr
# include "LPC214x.H" / / LPC2148 MPU Register
# include / / Para Usada função printf
/ Seção pototype * * /
init_serial0 void (void); / / initil UART-0
putchar (int ch); / / Put Char para UART-0
int getchar (void); / / Get Char De Uart-0
void delay (unsigned long int); / / Delay Time Function
unsigned int count;
tempx unsigned long int, tempy;
valx unsigned int / / Resultado ADC (HEX)
unsigned int valy;
float voltx / / ADC Resultado Volt
float Volty;
float ax, ay, um;int main (void)
PCONP | = 1 <<20; / / set Nguon cap PDA1 cho ADC1
init_serial0 (); / / UART0 inicial = 9600, N, 8,1
/ / chon ADC1.1 = P0.8 va ADC1.0 = P0.6
PINSEL0 | = 0x000033000; / / Select ADC8 Conectar-Pin P0.6
/ / ADC8 inicial (ADCR = 0x01210601)
AD1CR & = 0x00000000 / / Limpar todos os bits de controle
AD1CR | = 0x00000003; / / Select ADC1.1 va ADC1.0
AD1CR | = 0x00000600 / / ADC Clock = VBP (PCLK) / 7
AD1CR | = 0x00010000 / / Busrt = 1 = Conversão Continue
AD1CR & = 0xFFF1FFFF / / CLKS = 000 = 10 Bits: 11 ciclo de relógio de Conversão
AD1CR | = 0x00200000 / / PDN = 1 = Active ADC Module
AD1CR & = 0xFF3FFFFF / / TEST [1:0] = 00 = Modo Normal
AD1CR & = 0xf7ffffff / / EDGE = 0 = conversão em Queda Edge
AD1CR | = 0x01000000; / / start = 001 = Iniciar Conversão Agora
/ / P0.6 = Ax gia toc Theo truc x
/ / Start ADC8 teste de leitura e exibição em UART0 / /
while (1) / / Loop Continue
count = 1;
tempx = tempy = 0;
while (count -)
/ doc gia tri ADC1.0 ax = valx
fazer
valx = AD1DR0; / / Read A / D Data Registe-se e pouco clara FEITO
while (valx (& 0x80000000) == 0); / / Wait ADC Conversion Complete
valx = (valx>> 6) & 0x03ff;
/ / Printf (volt ");
/ Doc gia tri ADC1.1 ay = valy
do / / Loop Leia ADC1.1 (ADC8)
AD1DR1 valy =;
/ / Printf (voltx "1"); / / Read A / D Data Registe-se e pouco clara FEITO
while ((valy & 0x80000000) == 0); / / Wait ADC Conversion Complete
/ / loop porque ele sempre aqui
valy = (valy>> 6) & 0x03ff;
tempx = valx;
tempy = valy;
Volty tempy * = 3,3 / 1023.0/100.0;
voltx tempx * = 3,3 / 1023.0/500.0;
printf ( "voltx =% 1.2f \ n", voltx);
printf ( "VOLY =% 1.2f \ n", Volty);
delay (10000);
/ * UART0 inicial = 9600, N, 8,1 * /
/ * VPB (pclk) = 60,00 MHz * /
PINSEL0 & = 0xFFFFFFF0; / P0.0 / Reset, P0.1 Pin Config
PINSEL0 | = 0x00000001; / / Select = P0.0 TxD (UART0)
PINSEL0 | = 0x00000004; / / Select P0.1 = RxD (UART0)
U0LCR & = 0xFC / / Redefinir o Word Select (1:0)
U0LCR | = 0x03; / / Bit de dados = 8 bits
U0LCR & = 0xFB / / Stop Bit = 1 Bit
U0LCR & = 0xF7; / Paridade / = Disable
U0LCR & = 0xBF; / / Break Desativar Controle
U0LCR | = 0x80; / / Enable Programação do Divisor Travas
/ / U0DLM: U0DLL = 60,00 MHz / [16 x Baud]
/ / = 60,00 MHz / [16 x 9600]
/ / = 390,6 = 391 = 0187H
U0DLM = 0x01 / / Programa Divisor Latch (391) para 9600 Baud
U0DLL = 0x87;
U0LCR & = 0x7F; / Programação / Disable do Divisor Travas
U0FCR | = 0x01; / fif0 Ativar
U0FCR | = 0x02; / RX FIFO Reset
U0FCR | = 0x04; / / TX FIFO Reset
U0FCR & = 0x3F;
/ * Character Escreve Para UART0 * /
putchar (int ch)
if (ch == '\ n')
while (! (U0LSR & 0x20)); / / Wait TXD buffer vazio
U0THR = 0x0D; / / Write CR
return (U0THR = ch); / / Write Character
/ * Caractere lido a partir UART0 * /
int getchar (void)
while (! (U0LSR & 0x01)); / / Wait RxD Recepção de Dados Pronto
return (U0RBR); / / Get Receice Data & Return
/ * Delay Time Function * /
/ * 1-4294967296 * /
void delay (unsigned long int count1)
while (count1> 0) (count1 - / / Loop Diminuir Counter
unsigned int count;
unsigned int valy;
float Volty;
count = 1;
tempx = tempy = 0;
while (count -)
fazer
AD1DR1 valy =;
tempx = valx;
tempy = valy;
delay (10000);
U0DLL = 0x87;
U0FCR & = 0x3F;
putchar (int ch)
if (ch == '\ n')
int getchar (void)
