C a Assembléia Conversão
I
Ibrar
oi tudo
algum corpo pode converter seguintes códigos na montagem.Estes códigos são para jhd12864 GLCD.
Obrigado
# include <reg51.h>
# include <intrins.h>
uchar typedef unsigned char;
typedef unsigned int UINT;
sbit L_DI = P2 ^ 0;
sbit L_RW = P2 ^ 1;
sbit L_E = P2 ^ 4;
sbit L_CS1 = P2 ^ 6;
L_CS2 sbit = P2 ^ 7;
sbit L_SET = P2 ^ 3;
sbit TEST = P3 ^ 5;
float abc;
X1 código uchar [] = (
0x30, 0x50, 0xd0, 0x90, 0xF0, 0x30, 0x80, 0x60, 0x3c, 0xE8, 0x20, 0xa0, 0xE0, 0x70, 0x00, 0x00,
0x04, 0x06, 0x03, 0x11, 0x13, 0x12, 0x18, 0x0c, 0x07, 0x01, 0x03, 0x06, 0x0c, 0x1c, 0x18, 0x18
X2 código uchar [] = (
0x40, 0x58, 0x58, 0xd0, 0x10, 0xf8, 0x98, 0x08, 0x88, 0xf8, 0xF0, 0x10, 0xf8, 0x70, 0x00, 0x00,
0x0c, 0x04, 0x04, 0x07, 0x04, 0x05, 0x0d, 0x0d, 0x08, 0x1f, 0x1b, 0x19, 0x38, 0x38, 0x18, 0x18
X3 código uchar [] = (
0x30, 0x30, 0xf8, 0xf8, 0x08, 0x10, 0xd0, 0x50, 0x50, 0xfc, 0xfc, 0x50, 0xd0, 0xF0, 0x10, 0x00,
0x00, 0x00, 0x1f, 0x1f, 0x10, 0x10, 0x13, 0x1b, 0x0f, 0x07, 0x05, 0x0d, 0x09, 0x19, 0x38, 0x18
X4 código uchar [] = (
0x00, 0x00, 0x00, 0x00, 0xfc, 0xf8, 0x48, 0x48, 0x48, 0xf8, 0xf8, 0x48, 0x48, 0x48, 0xfc, 0xf8,
0x10, 0x10, 0x18, 0x1e, 0x0f, 0x01, 0x01, 0x01, 0x01, 0x3f, 0x1f, 0x01, 0x01, 0x01, 0x3f, 0x3f
uchar X5
0x18, 0xfc, 0x08, 0x48, 0x48, 0xb8, 0xd8, 0x58, 0xE8, 0xb8, 0xb8, 0x08, 0x08, 0xf8, 0xf8, 0x00,
0x00, 0x1f, 0x11, 0x11, 0x11, 0x14, 0x15, 0x16, 0x16, 0x10, 0x11, 0x11, 0x11, 0x3f, 0x1f, 0x00
X6 código uchar [] = (
0xc0, 0xc8, 0xc8, 0xf8, 0xf8, 0xc8, 0xf8, 0xf8, 0xc8, 0xc8, 0x00, 0x10, 0x90, 0xd8, 0x48, 0x48,
0x18, 0x18, 0x0c, 0x0f, 0x03, 0x00, 0x1f, 0x1f, 0x10, 0x10, 0x11, 0x19, 0x18, 0x0c, 0x04, 0x06
X7 código uchar [] = (
0x00, 0x00, 0x00, 0xE0, 0xE0, 0x40, 0x40, 0x7c, 0x7c, 0x58, 0x58, 0x58, 0xd0, 0xd0, 0x00, 0x00,
0x10, 0x18, 0x08, 0x0d, 0x03, 0x19, 0x0d, 0x01, 0x01, 0x0d, 0x19, 0x01, 0x07, 0x0c, 0x18, 0x38
X8 Código uchar [] = (
0x08, 0xf8, 0xf8, 0x48, 0xE8, 0x98, 0x90, 0xd8, 0xF0, 0xBC, 0xfc, 0xd0, 0x90, 0x90, 0x90, 0x10,
0x00, 0x3f, 0x1f, 0x02, 0x03, 0x05, 0x06, 0x07, 0x07, 0x06, 0x3f, 0x3f, 0x06, 0x06, 0x04, 0x04
uchar X9 [code] = (
0x10, 0x08, 0x1c, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x08, 0x04, 0x04, 0x98, 0xF0, 0x00,
0x80, 0x80, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0xE0, 0x90, 0x8A, 0x83, 0xc1, 0x00
) / * 12 * /
X10 código uchar [] = (
0x00, 0x78, 0xc8, 0x84, 0x04, 0x84, 0xf8, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80,
0x00, 0x78, 0x84, 0x83, 0x83, 0x8e, 0xfc, 0x40, 0x00, 0x80, 0x63, 0x17, 0x1c, 0xf2, 0xc1, 0x80
) / * 8x * /
X11 código uchar [] = (
0x00, 0x80, 0xE0, 0x10, 0x08, 0x04, 0x04, 0x00, 0x00, 0x00, 0x80, 0x60, 0x10, 0xf8, 0x00, 0x00,
0x00, 0x7f, 0xc2, 0x81, 0x81, 0x81, 0x7f, 0x18, 0x00, 0x0e, 0x09, 0x08, 0x08, 0xff, 0x08, 0x08
) / * 64 * /
X12 código uchar [] = (
0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA,
X13 código uchar [] = (
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
X14 código uchar [] = (
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
X15 código uchar [] = (
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
X16 código uchar [] = (
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80
X17 código uchar [] = (
0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
X18 código uchar [] = (
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff,
X19 código uchar [] = (
0xff, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
uchar código X20 [] = (
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0xff,
X21 código uchar [] = (
0xff, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80
X22 código uchar [] = (
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0xff
X23 código uchar [] = (
# pragma REGISTERBANK (0)
initcomm (void)
PCON = 0x80; TMOD = 0x21; SCON = 0x50;
TH1 = 0xFA; TL1 = 0xFA; TR1 = 1; ES = 1;
TH0 = 0; TL0 = 0; TR0 = 1; ET0 = 1;
EA = 0;
delay (void)
uchar i, j;
abc = 0,1 * 5;
for (i = 0; i! = 0xff; i )
for (j = 0; j! = 0xff; j );
void LCD_C_D (sinalizador de bit, ldata uchar) / * flag = bandeira 1 con = 0 dados * /
uchar i de dados;
L_DI = flag!; L_E = 0; P0 L_RW = 0; = ldata;
_nop_ ();
L_E = 1;
_nop_ (); _nop_ ();
L_E = 0; L_RW = 1; L_DI = 1;
for (i = 0; i <10; i );
void dis_one_zi (uchar x_add, uchar código, y_add uchar * po)
uchar i, j, w;
j = x_add * 2 0 xb8;
w = (y_add <4? y_add: y_add-4) * 16 0 x40;
L_CS1 = (y_add <4);
L_CS2 =! (Y_add <4);
LCD_C_D (1, j);
LCD_C_D (1, w);
for (i = 0; i <32; i )
if (i == 16)
LCD_C_D (1, j 1);
LCD_C_D (1, w);
LCD_C_D (0, * po );
L_CS1 = L_CS2 = 0;
void CLRLCD (número uchar)
uchar dados i, j;
L_CS1 = L_CS2 = 1;
for (i = 0xb8; i <0xc0; i )
LCD_C_D (1, i);
LCD_C_D (1,0 X40);
for (j = 0; j <0x40; j )
LCD_C_D (0, número);
L_CS1 = L_CS2 = 0;
void main (void) utilizando 0
uchar dados de número i, j,;
Código uchar * p;
initcomm ();
L_SET = 0;
L_SET = 1;
LCD_C_D (1,0 x3E );/**/
LCD_C_D (1,0 xc0 );/**/
LCD_C_D (1,0 X3F );/**/
CLRLCD (0);
while (1)
CLRLCD (0);
LCD_C_D (1,0 x3E);
X15 p = ;/*????*/
for (numero = 1; número <7; número )
(Dis_one_zi (0, número, p);)
p = X16;
(Dis_one_zi (3, número, p);)
X17 = p;
for (numero = 1; número <3; número )
(Dis_one_zi (número, 0, p);)
X18 = p;
(Dis_one_zi (número, 7, p);)
X19 = p; dis_one_zi (0,0 p);
p = X20; dis_one_zi (0,7 p);
X21 = p; dis_one_zi (3,0 p);
X22 = p; dis_one_zi (3,7 p);
X1 = p; dis_one_zi (1,1 p);
X2 = p; dis_one_zi (1,2 p);
X3 = p; dis_one_zi (1,3 p);
X4 = p; dis_one_zi (1,4 p);
p = X5; dis_one_zi (2,5 p);
p = X6; dis_one_zi (2,6 p);
p = X7; dis_one_zi (1,5 p);
X8 = p; dis_one_zi (1,6 p);
/ * 128X64 * /
p = X9; dis_one_zi (2,1 p);
X10 = p; dis_one_zi (2,2 p);
p = X11; dis_one_zi (2,3 p);
X23 = p; dis_one_zi (2,4 p);
LCD_C_D (1,0 X3F);
delay (); delay ();
CLRLCD (0);
LCD_C_D (1,0 x3E);
X12 = p;
for (numero = 0; número <4; número )
for (i = 0; i <8; i )
(Dis_one_zi (número, i, p);)
LCD_C_D (1,0 X3F);
delay (); delay ();
CLRLCD (0);
LCD_C_D (1,0 x3E);
X13 = p;
LCD_C_D (1,0 X3F);
delay (); delay ();
CLRLCD (0);
> Algum corpo pode converter seguintes códigos na montagem.
É claro.A C-compilador poderia.
Apperently, este destina-se a 8051 e é um Keil-trecho específico.Você pode usar o compilador de '51, como SDCC, mas você precisa fazer algumas modificações (por exemplo, a porta de pinos definições são um pouco diferente - leia o manual).
JW
