Código ASSEMBLEIA para 89C51 usando RS232
V
vanbayhoang
Por favor, qualquer um pode me fornecer o código ASSEMBLEIA with89c51 usando RS232!
; = EM NOME DO ----- =
; a SMS ENVIAR
;-------------------------- BYTE CESSÃO --------------------- ----------------------
;-------------------------- PORT CESSÃO --------------------- ----------------------
LED1 EQU P2
LED2 EQU P0
ORG 00H
JMP INIT
ORG 23H
JMP S0ISR
ORG 30H;================================================= =====================================
INIT:
MOV LED1, # 00
MOV LED2, # 00
MOV B, # 00
MOV TMOD, # 20H; SELECÇÃO MODE 2 (8 BIT AUTO RELOAD) do Timer1.
MOV TH1, # -3; 9600 taxa de transmissão para Comunicação Serial.
MOV SCON, # 50H; SELECÇÃO MODE 1 (8 BIT DATA, 1 STOP & 1 START BIT), PARA Comunicação Serial
SETB TR1
PAUSA CALL
PAUSA CALL
PRINCIPAL:
CALL SEND_SMS
JMP MAIN
SEND_SMS:CALL ATC
CALL CARRET
PAUSA CALL
CALL CMGF
CALL CARRET
PAUSA CALL
CALL CMGS
CALL CARRET
PAUSA CALL
SMS_MESSAGE CALL
PAUSA CALL
CALL CTRZ
MOV A, B
A CPL
MOV B, A
MOV LED1, B
RET
SMS_MESSAGE:
MOV DPTR, # SMSMSG
CALL CONF
RET;================================================= ==================================
S0ISR:CLR RI
MOV A, SBUF
MOV @ R0, A
INC R0
RETI;================================================= =====================================
NOWDEL:
ACALL ATC
ACALL CARRET
ACALL CMGD
ACALL CARRET
RET
ATC: MOV R2, # 00
MOV A, # 00
MOV DPTR, # MES9
CLR TI
String9:
MOVC A, @ A DPTR
MOV SBUF, A
JNB TI, $
CLR TI
ACALL ATRASO
INC R2
MOV A, R2
CJNE R2, # 2, String9
RET
CARRET:
MOV R2, # 00
MOV A, # 00
MOV DPTR, # CAR
CLR TI
String3:
MOVC A, @ A DPTR
MOV SBUF, A
JNB TI, $
CLR TI
ACALL ATRASO
INC R2
MOV A, R2
CJNE R2, # 2, string3
RET
CMGF:
MOV R2, # 00
MOV A, # 00
MOV DPTR, # MES6
CLR TI
Seqüência6:
MOVC A, @ A DPTR
MOV SBUF, A
JNB TI, $
CLR TI
ACALL ATRASO
INC R2
MOV A, R2
CJNE R2, # 9, seqüência6
RET
CMGS:
MOV R2, # 00
MOV A, # 00
MOV DPTR, # MES15
CLR TI
STRING15:
MOVC A, @ A DPTR
MOV SBUF, A
JNB TI, $
CLR TI
ACALL ATRASO
INC R2
MOV A, R2
CJNE R2, # 21, STRING15
RET
CPMS:
MOV R2, # 00
MOV A, # 00
MOV DPTR, # MES17
CLR TI
STRING17:
MOVC A, @ A DPTR
MOV SBUF, A
JNB TI, $
CLR TI
ACALL ATRASO
INC R2
MOV A, R2
CJNE R2, # 12, STRING17
RET
CMGR:
MOV R2, # 00
MOV A, # 00
MOV DPTR, # mes7
CLR TI
STRING7:
MOVC A, @ A DPTR
MOV SBUF, A
JNB TI, $
CLR TI
ACALL ATRASO
INC R2
MOV A, R2
CJNE R2, # 9, STRING7
RET
CMGD:
MOV R2, # 00
MOV A, # 00
MOV DPTR, # MES8
CLR TI
String8:
MOVC A, @ A DPTR
MOV SBUF, A
JNB TI, $
CLR TI
ACALL ATRASO
INC R2
MOV A, R2
CJNE R2, # 9, String8
RET
CTRZ:
MOV R2, # 00
MOV A, # 00
MOV DPTR, # MSG16
CLR TI
String16:
MOVC A, @ A DPTR
MOV SBUF, A
JNB TI, $
CLR TI
ACALL ATRASO
INC R2
MOV A, R2
CJNE R2, # 1, String16
RET
CONF:
MOV R2, # 00
MOV A, # 00
CLR TI
STRING10:
MOVC A, @ A DPTR
CJNE A, # 2AH, TRANS
RET
TRANS: MOV SBUF, A
JNB TI, $
CLR TI
CALL DELAY
INC R2
MOV A, R2
JMP STRING10;
DELAY:
MOV R4, # 100
HERE2:
MOV R3, # 255
AQUI:
DJNZ R3, AQUI
DJNZ R4, HERE2
RET
CLRMEM:
MOV R0, # 84H
DOAGAIN:
MOV @ R0, # 0H
INC R0
CJNE R0, # 0FCH, DOAGAIN
PAUSE:
MOV R7, # 64
COOLIT: ACALL ATRASO
DJNZ R7, COOLIT
RET
; = Look Up Table =
MES6: DB "AT CMGF = 1 ","*"
Mes7: DB "AT CMGR = 1 ","*"
MES8: DB "AT CMGD = 1 ","*"
MES9: DB "AT ","*"
MES15: DB "AT CMGS =", 022H, "03333184821", 022H, 0
MSG16: DB 01AH, "*"
MES17: DB "AT CPMS =", 022H, "ME", 022H, 0
CAR: DB 0DH, 0AH, "*"
SMSMSG: DB CONTROLO "SMS DE TRANSMISSÃO ","*"FIMAtenciosamente
Naveed Khowaja
You are welcome ...
Obrigado
Atenciosamente
Naveed Khowaja
